Hey all!
I'm a new pool owner, just put up my above-ground pool, an intex 18 ftx52. I bought a Taylor 2006c test kit and a bottle of aquacheck test strips to try out and use as a secondary source of info. After my first round of testing both the results and a strip confirmed that my TA was 180 and pH was between 8-8.4. According to the "lowering TA" info page on the TFP's site one should not adjust the TA simply to meet a target number/value and yet both my pH and TA are high.
Q1: Should I add acid to lower the TA? Or, as I haven't added any chemicals to the pool yet, should I focus on getting the Free Chlorine and CYA up to value first, retest and then worry about adding the acid?
The other question I have is regarding the test kit. Under the instructions for testing the Free Chlorine it says if the water doesn't turn pink after adding the white powder one should keep adding the powder until it turns pink. Knowing that the pool should read almost zero for FC as I've never added any before I wasn't surprised to see that the water barely turned pink after adding the powder, it was almost translucent pink. However I kept adding a few more doses of the powder and the color stayed barely pink and didn't change.
Q2: Does the "keep adding the powder" part really just apply to when I've already added Free Chlorine or should I have kept adding the powder even if it required using a lot of it to make it turn more pink? I was hesitant to keep wasting the powder when I already know that Free Chlorine is so low its almost non-existent.
When I completed all the steps for testing the Free Chlorine the results showed that my levels were .6 which I'm already doubting is accurate because I shouldn't have any.
Thanks so much guys
Thanks so much guys
