- May 3, 2014
- 58,656
- Fiberglass
- Pentair Intellichlor IC-40
It is best to have some straight pipe before the SWCG. I would not stress on getting exactly 12" or more. What you are trying to do is reduce the turbulence prior to the flow switch in the IC40. Some folks have no issues with essentially 0 straight pipe before the SWCG . Remember you can go vertical with the SWCG. Read your owners manual on how to do that.
It may also not make much difference that the SWCG is on the bypass loop unless you plan to heat your POOL water for long periods of time. If you primarily only heat the spa, then it will not matter much as the SWCG goes to only 1 or 2% generation setting in spa mode.
