- May 3, 2007
- 18,074
- Plaster
- Hayward Aqua Rite (T-15)
I did a few head loss calculations and here is what I came up with.
Feature Recommendations:
6' Sheer - 90 GPM
3x1' Sheers - 45 GPM
1 Bubbler - 40 GPM
6 Jets - 30 GPM
Total Recommended Flow Rate: 205 GPM
Assumptions:
3" 45' Suction + 5 90s
1 Cartridge Filter
4 x (2.5" 45' Lines + 5 90s)
Feature head loss based upon documentation and flow rate balance to each element
Combined Plumbing curve = 0.002 (Curve E below)
Operating points:
WhisperfloXF: 181 GPM @ 65' of head
IntellifloXF: 167 GPM @ 56' of head
Intelliflo3: 154 GPM @ 47' of head
Technically, none of the pumps will provide the maximum flow rate recommended so you might be better off with two pumps. One for the sheers and one for the rest. This might be a better solution since shutting off one feature will require rebalancing the rest of the features for proper flow rate. Using a single pump for multiple features of differing head loss can be a challenge for balancing the flow rates as features are turned on and off.
Another option would be to use two very small pump's below DOE regulations, one for the bubbler and one for the deck jets. A 1/2 HP pump would probably be sufficient for those applications.
6' Sheer - 90 GPM
1 Bubbler - 40 GPM
6 Jets - 30 GPM
Assumptions:
1 Cartridge Filter
Operating points:
