Shotcret is in and I guess now the real problems start. Whoever is supposed to monitor this apparently forgot to check the skimmer height/ form height 🤦♂️
The plumbing leak was in the pump and filter seal.
At my preferred water level height (middle of water line tile) the water in skimmer #1 would be 1-3/4" below the top of the opening and in skimmer #2 1-1/4" below the top of the opening. The waterline tile had to be raised 1" above the Shotcrete on that side of the pool because the other side of the pool turned out to be 1" higher.
I very much assume that having the water that high in the skimmer is not ideal. Lowering the waterline is not really an option because then the water level on the wet deck would be too low (also I don't like a big gap between coping and waterline.
(The tile job around the skimmers is bad and will be fixed)
Also it seems like I bought 12" skimmers (SKR15103 AquaStar Bonded Skimmer) instead of 6" or is it normal that the skimmer extends 6" below the waterline?
Another question regarding the tile. My tile guy told me that the tile will be 1/2" out which is also what the pebble applicator was asking for. I measured it and it is only 3/8" out. Should that be another concern?
