I have the pump running all day. The pool guy recommended to run it at 2800 RPM for a few hours (1pm to 5 pm) and let it run at 1800 RPM for the rest of each day. So I have done that. However, I have noticed that the PSI (as measured at the filter) goes down to only 2.5 PSI when running at 1800 RPM, but it goes to 12.5 PSI when running at 2800 RPM. Is that normal?
The system seems to be completely free of air when it runs at 2800 RPM because viewing through the glass cover/window on the pump shows no bubbles whatsoever. But, when the pump goes to the lower RPM the clear window at the pump does show to have a lot of air. Is that normal?
tf,
Your VS pump is working perfectly....
Filter pressure is really the amount of effort it takes for your pump to push the water through your filter... If you think about it that way, it makes perfect sense that it takes less effort (2.5 PSI) to push a little water through your filter and a lot more effort (12.5 PSI) to push much more water through your filter...
I run my VS pump at 1200 rpm 90% of the time, when I do my filter pressure is also down around 2 lbs. and I get half dollar size air bubbles under the pump lid.. This is quite normal with VS pumps. The key, in my mind, is that the bubbles do not move through the system and out into the pool. Other than maybe right at start up, no air bubbles should be coming out of your pool returns.
Thanks for posting,
