Your water is so clear and sparkly, too! Makes it easy to watch the guy! I too thought it odd that he would go in with street clothes!
I have enjoyed your photos of pool project ,
I see you are part of an HOA and have got flack for your propane tank here is and idea for you to have it blend into your surrounding landscape . You can also Google painted propane tanks or wraps![]()
Sent from my iPad using Tapatalk
OK guys I am thinking maybe my pool has cured . . . my numbers are starting to stabilize - in the past - every day the numbers could jump up down - crazy - really make you feel like you don't know how to test
My PH has been raising daily - pretty much every other day I was having to add acid to drop it back down. But for the past 6 days my PH is 7.5 My CL is staying around 7 (using the drop test) - the quick test only goes up to 5 - so I don't even understand why we have it. But anyway.
PH 7.5
CL 7
CC 0
My CH is 300
TA is 70
CYA is 30-40 (I FINALLY have enough that the dot disappears - but I am not sure what reading to do. The dot gets fuzzy and I have to focus and move it around to try to see it at 30 - if I go up to 40 it is gone for good. What reading would you put?
So - if this is true and my pool continues to hold numbers, from my understanding that means my Pebble Tec has cured? I could ask for pool school now if I wanted - or I can wait and let them keep providing all the chemicals to treat the pool.
Do my numbers look ok (for a brand new pool that is adjusting and getting a LOT of swimmer load)?
