Are you looking to put loungers on the Baja step? Lay out some towels the size of the loungers you are thinking of getting them "draw" the step out around them to see which side works for you. Think about the fact that the Baja step will be the main access into and out of the pool. Will there be room for others walking around the loungers to get to the pool?
The port looks like it is in the purrfect spot.
Kim![]()
One quick note that a couple of us owner builders have learned: after plumbing is done, get system pressurized and monitor the psi at each milestone (before gunite, before patio, etc). With so many people working on your pool you'll want to make sure nobody compromises its integrity.
The "V" near the skimmer is the suction port. I wonder if that location is okay? Seems alright & less noticeable. Let me know what you think.
Also, I think I'm going to have them shrink the Baja step to 9X10, 11X11 seems a little large.
Sounds good! Like I said, I'm not an expert, but if you're wanting to run an automated suction cleaner, having a relatively even length of hose in either direction (plus or minus a foot or two) is key to getting full coverage.
NICE! I like it!
Kim:![]()
