Perfect and just so Im reading the chart correctly that would be a 6 for 30 CYA correct? Try to maintain 4-6 FC. So Every day I add to achieve a 6 FC. Or wait till I read a 4 to add? Sorry if these are dumb questions. haha
Add liquid chlorine to raise the FC to 6 ppm, circulate the pool for 30 minutes, and test FC.
What age is the liquid chlorine that you have?
Just checked my TA and it is at 120 this about normal? Hasn’t changed since I changed my water.
TA is what it is. There is no normal or abnormal.
What is the pH and TA of your fill water?
TA can be forced down by...
Lower Total Alkalinity - Trouble Free Pool
A lower Total Alkalinity level can help a pool owner stabalize their pH increase. We'll explain how to lower TA with a little help from muriatic acid.www.troublefreepool.com
TA - Further Reading
With lower water temperature, the tablets will not dissolve quickly. I would imagine even one will have a hard time dissolving in the week.
Best to raise your FC to mid SLAM level or so prior to leaving. As all things work slowly in low water temperatures, I doubt you will see a problem even if your FC falls below target for a day or two.
