Putting in an above ground 18x36 oval pool, approximately 14,000 gallons. The dealer recommended a Hayward VS 700 1.65 HP pump with Hayward C200S single element 200 sq ft cartridge filter. The pool will have 1 skimmer and 1 return. A couple of questions:
The pool installer said to go with a sand filter instead of cartridge due to having to clean it “every 2 weeks.” What I’ve read on here is that you only have to clean cartridge filters twice a year if you get a large enough one. Is the 200 sq ft filter size high enough for my size pool, or should I upgrade to a 325 sq ft cartridge filter?
Do I need to add a second return? The installer says it is not necessary, and he has never seen anyone do it on an above ground, but he will do it if we want. He recommended upgrading the pump to a 2 hp pump to help with water flow/return if we wanted. Would this be helpful? Or should we plumb and add the second return? Or would 1 return with the 1.65 HP pump be ok? Thanks!
