I slept pretty well, digging and in the sun then being a dad of 4 trumped any sunburn.
Pool related note:
Brushing is your friend, haven't done it in about 3 days due to working inside at night other than testing and adjusting for shock level.
Lesson learned: with not seeing bottom, assume there is algae chilling on the bottom and use the FULL LENGTH of extendable pole to get to the middle.
Reason: got out just now to check/adjust and decided to brush with fully extended pole. Ended up turning my pool slightly green again from brushing the algae from the middle . 10 mins later, filter psi jumped up 10psi.
****WARNING****
Optimism ahead...
At least I know why the pool color/clarity wasn't changing a whole lot over the past several days, and it can only get better from here!
