phonedave
- May 30, 2012
- 1,988
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
So, let me ask you this, since you seem to have a ton of experience in this area. Would you leave the tub chlorine, or would you convert to salt, if the money weren’t a consideration?
The chlorine isn’t really bothering my skin. I truly feel like the non chlorine shock was what made me break out. The day after I put that in, my back was a bumpy, itching mess. Since purging with Ahhsome and starting over, I’ve been fine. But I’m having to add chlorine after every single use. And what do I do to eliminate the CC’s and to replace the weekly shock, if I want to continue using the tub every day and not taking days off?
Salt is chlorine, so if chlorine bothers you so will salt. The sodium chloride that is salt gets changed into chlorine.
MPS aka Non Chlorine Shock can cause allergic reactions in some people.
I have a salt system in my pool and would put one in my tub in an instant. As I said, the only thing that stops me is the extension cord and non-integrated aspects of a drape over system.
You should be adding chlorine after every use, that is just part and parcel of running a hot tub. You are soaking your sweaty body in a small pool of water, you are going to have to add chlorine after using it.
Leave the top open for a while to let CC's vent. Even if you shock, you can still use the tub the same day
