Hi, I am a new homeowner with a pool in the Los Angeles area and have maintained the pool since the beginning of 2022. The pool is an in-ground plaster holding ~14k gallons. I have been looking through this forum gaining lot of good information. There are wealth of knowledge on this site . With the summer starting, I am starting to see some green algae growth in parts of the pool.
I have been running the pump (2.5" pipe) for ~5 hours during the winter (1300 rpm) and have increased to 9 hours in the summer (1300 rpm) + 1 hour (2300 rpm). I am using trichlor tablets (one 3" puck per week, increased to three 3" puck two weeks ago) and have been brushing and vacuuming once every couple of weeks. As part of the maintenance, I clean out the skimmer and pump baskets. I have just cleaned out the Hayward Swimclear cartridge filters (qty=4) opening the filter head. The filters were quite dirty.
Overall, the water has been visually clear. I added 2 gallons of 10% liquid chlorine (1 week apart) the last couple of weeks while I awaited arrival of the TFT-100 test kit. The green algae growth is slowing down with brushing every couple of days.
Today, I tested the water in the morning and am getting the following measurements. I have removed the chlorine tablets due to the high CYA reading. I may have to replace some of the water to lower the CYA based on what I am reading here?? I will also have to increase the Free Chlorine (FC) level based on the CYA reading?? The Calcium Hardness (CH) is surprisingly high.
I would like to ask the forum for advice getting the water chemistry to recommended levels. Chemical recommendations would also be greatly appreciated. Thank you!
pH = 8.2
FC = 4 ppm
CC = 1 ppm
CH = 1700 ppm
TA = 220 ppm
CYA = 140-150
pH = 8.2
FC = 4 ppm
CC = 1 ppm
CH = 1700 ppm
TA = 220 ppm
CYA = 140-150
