- May 3, 2014
- 58,767
- Fiberglass
- Pentair Intellichlor IC-40
Sure. Organics consume chlorine.Is that normal for it to burn off that fast, when doing the SLAM?
Are you referring to the M in SLAM? If so, it means to maintain the shock level, 22 in your case (which isn't a valid level - this means that you measured a CYA of 55,which isn't possible with any of the kits endorsed by this forum. You should round up to 60 and use 24 as your SLAM target.)how do I start Maintanence?
