Asked the PB to quote us a price on making the 8 bubblers in the waterfall walls color changing bubblers, very pricey, not going to happen. I think we are just going to put a light in the water well instead.
Thanks for confirming the Screenlogic question for me.No screenlogic required for the Intellicenter. I would ditch the UV. I am removing the UV my PB installed, because I didn't do my homework on these systems prior to signing the contract.
You can search the forums here for UV sanitation and determine for yourself. The general consensus is that it is not necessary for an outdoor pool. There are other reasons as well, but you should come to your own conclusions on whether it will work for you, don't just listen to the PB.
--Jeff
Do you know if you're getting a bundled IntelliCenter system? That'll include the WiFi client bridge which you'll need to connect your your local network unless you plan on using Ethernet wiring.
Darn! Did not really think about that but what he says makes sense
I DO love the idea of the pillar with a water bowl on top...............did you know there are water/fire bowls???? SO pretty!! Do a search and let us know what you and your wife think!
We are not doing two different ones the PB just did one side so we can compare.I like the wall spouts-RAHHHHHH says that lion! I do not care for the two different "walls". What I would love to see would be the bubblers (2) to be where they are on both side then the a lion being on each pillar. A wall on each side with two bubblers each and a lion on each pillar. So 4 bubblers and 4 lions.
