I’m new to using a cartridge filter. I just starting using a new cartridge and had it running all night. When I checked the cartridge the next day just the bottom was green with algea the top was still clean white. Is that normal? Thank you
712,Thanks guys for the quick responses!! Very helpful. Yes I am aware of the alge and will have that fixed with the links provided.I was more concerned about the filter Cartridge only being half used. The old one I took out I saw dirt up to the top. The house I rented the pool was left unattended for some time it looks like. I will work on my signature shortly with all my equipment details. Again thanks to everyone.
The first thing I looked at....... Yup, they’re from Florida. This one could go either way because one of the plethora of facts I’ve learned here is that FL builders like small filters.A properly sized filter will go a long time between cleaning
collects in my skimmer socks (actually inexpensive hair nets from Amazon). I clean them out every day or two
N,
Yes, the pack of 100 is what I buy.. They last me forever.
You will most likely have to put a rock in the skimmer basket to keep the hair net from floating up with the pump on slow or off. Make sure the rock is smooth and too big to go down any pipes.
Jim R.
Pollen that would normally coat your filter I was surprised when I started using them how much " junk" they caughtThey are perfect for collecting pollen.
Just be aware to check them daily. A ton of pollen coating the sock can clog up good flow easily
