- Jul 17, 2019
- 3,787
- Plaster
- Pentair Intellichlor IC-40
I responded to the other thread, but in summary the PSL4 is not a good "automation" and will not allow you to do the basics like accessing it from your phone, tablet, electronic device. You at least need to add in Screen Logic which lets the Easy Touch do all of that, and the price difference between EasyTouch + Screen Logic vs the Intellicenter shouldnt be that much.I was quoted $2,400 difference from the EasyTouch PSL4 to the IntelliCenter for upgrade and programming...do you think it is worth the difference in cost?
If you dont add screen logic or upgrade to the Intellicenter, you will have to walk to the equipment pad to change anything. If you have to do that you might as well remove the Easy Touch and move the valves and change pump speeds manually.
