You should be able to get all those covers in black. We have them all In black.
Yes, I've found them in black and dark gray. We figured we would wait until spring is here. The pockets are quickly drying up
I really like your dark liner...great looking pool
Sent from my SAMSUNG-SM-G930A using Tapatalk
Sunny, did you test the fill water? I can't remember and am too lazy to look back LOL
TA is the last thing we adjust so that is okay for now. It IS high but it is easy to fix. Time consuming but easy. We will work on it.
PH is really not that bad. It will sneak higher though so that does need to be watched. TA and PH go hand in hand. Right now you are fine
CH-the fill water may be that high. TX and AZ deal with this and more all of the time. It is fine for your vinyl.
FC is the one I worry about as without FC you may get algae. The cool temps are working in your favor. I would think about putting in a jug of bleach if there are no pucks in the feeder.
tell you hubby you have gone to the finest Pool School out there! TFP! LOL But your PB does hold the warranty card so hubby is right to tread with care for right now.
Kim
What vacuum do you have? I bet I can teach you how to use it!!!!! Shot me a picture and we will go from there!
I would add some FC just to be on the safe side.
Kim
They will be fine. It is a little high so their suits might be a little lighter than before. I would go out and squeeze the sock to get the CYA dissolved and into the pool.
Keep a journal of your levels and what your cell is set at. After a while you will get it dialed in. There will be some tweaking as you learn it all. The weather will play a role in the tweaking as it changes. You are in a major leaning curve right now so don't worry too much. We can help as needed. You are doing a fine job!
Kim
Is this a lathem brand steel wall pool?
My husband and I are looking to build a pool in the next year or so, and I love your pool! How has the shape/size worked for you? One of the pool builders we've talked to seemed to really want us to have a much larger lagoon, but it seemed rather... beastly in size.
