We are excited about having our pool build, a lot of great information on this form. See below a summary of our new build. Please feel free to review and share your critique, feedback, questions, or comments.
Shape: Geometric ~36’ Long X 18’ Wide (Including Beam)
Linear Perimeter Feet: ~116
Water Type: Chlorine
Square Feet Surface Area: ~618 Sq. Ft.
Depth: ~3’6” X 5’6”
Steel Specs:
Beam – ½” #4 Rebar 4 Bar Box Beam
Grid – 3/8” #3 Rebar on 8” Centers
Dam Walls – All Double Curtain Steel all 3/8” #3 Rebar on 8” Centers
Gunite – 7 to 1 Sand to Cement ratio / Minimum 12” gunite beam - Minimum 6” Walls & Floors / Approx. 7” Cove
~ 12” H X 18” H X 12” H X 36’ L – Raised Water Feature Wall w/ (3) 18” Sheer Descents
~6’ 3” X 10’ Tanning Ledge w/ 2 Bubblers at front entrance w/ Umbrella Anchor
~16’ X 18” Bench along the left side wall
Coping – 24” Travertine. Coping is typically high-end travertine material (e.g. Ivory, Noce, Autumn).
Waterline Tile – Standard Porcelain Ceramic (Frost-proof)
Accent Tile – If Requested (standard frost-proof tile)
New Decking - ~360 Sq. Ft. Spray Deck Concrete
Topping Existing Areas – Yes ~287 Sq. Ft.
Specs – Rebar on 16” centers. Average @ 4” thickness
Drainage Details – Standard channel drain or area drainage (depending on decking configuration) w/ gutter downspout connections as necessary
Wet Edge Pebble Category 1 Included (Plaster Options and Associated Cost Adjustments Below)
Pool Automation System – Pentair Easy Touch PSL 4 w/ ScreenLogic Smart Phone Application Controls
Standard Control System – N/A
Filter System – Pentair Clean & Clear 520 Plus Cartridge
Main Pool Pump – Pentair Intelliflo VSF 3HP Variable Speed Pump
Water Feature Pump – 1 HP WhisperFlo Pump (Bubblers & Wall Features)
Sanitation System – CMP POWERCLEAN Tab Ultra VS In-Line Chlorinator (Clear Lid)
Pool Lights – (2) Pentair IntelliBrite Color 5g LED 26 Watt
SuperPro Auto-Fill
• 2” Pool Suction
• All separate lines are 2”
• Sch 40 PVC Pipe for all major pool plumbing
• 2” Returns to first T for Pool
• Hi-Temp Unions on all Pump Connections
• Backwash Line to P-Trap @ Sanitary Sewer Installed (Where Required)
• Dual Surface Skimmers for optimum surface water circulation
• Full Circle Drains on Pool, Dual Anti-Vortex Drains for Water Feature
• Circulation – (6) top returns, (2) bottom returns, (2) returns in tanning ledge (bubblers)
Pentair Prowler 920 IG Robotic Cleaner
Depth: ~3’6” X 5’6”
Steel Specs:
SuperPro Auto-Fill
• 2” Pool Suction
