After over a year of waiting and researching we are finally ready to start our pool build. I am thankful for the knowledge I have gained from this forum. We are in the process of getting quotes from pool builders. Before they come out I want to make sure I got all the details down.
14X29 freeform IG gunite (with screen enclosure)
3.5 shallow, 5 deep (i know most say 4' shallow end but i like 3.5')
6x6 gunite spa (Yes, i have been in one before)
Tanning Ledge with 2 bubblers
Color LED lighting
Propane heater for the Spa/pool
Solar heater for the pool (to be installed later)
Automation
SWG rated for 2x pool volume
Cartridge filter rated 2x pool volume (is this necessary with a screen enclosure)
home runs for skimmer and main drains
Light at the equipment pad
Variable speed pump
Jandy style neverlube valves (as opposed to what?)
Questions
-is it necessary to have home runs for all the returns?
-is 2' inch plumbing sufficient for pool or should i go to 2.5 or 3"inch?
-is 3"inch plumbing for the spa recommended?
-should i have a return on the tanning ledge?
-Since the I have a screen enclosure is one skimmer sufficient or should I get two?
-I plan on doing solar for the pool. Should i put two returns in the deep end on the bottom for convection heating?
-Should i expect to have two pumps (one for pool/solar and the other for spa/bubblers)
-For the spa should i use a 400,000 BTU heater
Thanks for all the great advice
Color LED lighting
Automation
Variable speed pump
Questions
