- Jul 21, 2013
- 55,055
- Plaster
- Pentair Intellichlor IC-60
Today Ph 8 Calcium 160. I'm hesitate to make any adjustments (warranty) since the pool builder is still in charge of the water chemistry. I have been brushing twice a dayWHat are your current test resutls and what have they been for the last while? Have you been brushing it often?
Is it ok to add muriatic acid to pebble that is only 2 weeks oldYou need to get the pH under control. Like I said it may be much higher than 8. ph and TA play the biggest part in the overall health of your plaster long term.
Thanks, Can I add to much acid? I understand new plaster has high PH so is it common to add acid everyday (according to pool math?) Thanks again newbie here!!It is VERY okay to add it. It is the NOT adding it that will do the damage because of the pH levels.
Make sure the pump is on high. Pour it in slowly right in front of a return. Make sure you have eye protection on and have something close to wash/rinse the surrounding area just in case you get some on the coping or deck. Some people carry the jug in a bucket to such to make sure there is not dripping where you do not want it.
I am glad to see you got the pH down into the 7s! Was it hard?
Not at all! Was super easy and I was surprised how quickly it came down!!
Remove the tablets (pucks) from skimmer. That is not good for equipment. Go buy a floater to put them in or hang in a sock on a floating toy. The pucks are adding some CYA but not noticeable as it takes a long time for that to register. I am sure the PB will add dry stabilizer later. You may want to add some liquid chlorine to up FC.What about the low FC level? Should I add some bleach? There are tablets in the skimmer
What ever happened with your scale on the spa stacked stone ?What about the low calcium level should I increase it during startup phase?
Again, the pool is in startup phase so the SWG is off (chlorine only pool)
Todays test result
PH 7.8
TA 80
FC 1-2
CC 1-2
Both FC and CC had very light colors
Thanks! We are pleased but it has been a loooong process.What ever happened with your scale on the spa stacked stone ?
What plaster startup guide are you following for the first 28 days?
