- Jun 8, 2020
- 590
- Plaster
- Pentair Intellichlor IC-40
Agree, the Pour-a-lids look great, not to mention the whole project!
Thanks! We're really pleased with the progress and results.
Hi, how did the Sundek turn out? I love watching your build!
That looks sweet! Here in SA we're FINALLY getting some much needed wet stuff from above. Good day to sit back and look at the pool get a fresh top-off. Your project is looking fantastic.
That deck drain doesn’t look removable. Those tend to get clogged up and stop functioning and look pretty terrible after a while. If you could still swap in a removable one..may not be worth it at this point though.
On the off chance that you didn't already know, make sure you do not change the ground level near those trees (i.e., don't fill in the planter or raise the ground level outside of the planter). If you were to make a planter and fill it with dirt the trees will die in a couple of years.We're going to use moss rock on top of this footer, to create a planter where the 4 trees are. On this side of the footer, will be flagstone decking, stretching from the deck step (on the right) all the way to the deep end pool step (on the left).
WOW, that looks great! You should be swimming in no time now!So yesterday, the mason finished his work
Looks like a great place for a hammockWe're going to have the mason face the exposed gunite, and the side of the deck, with thin moss rock ... to create a perimeter of moss rock around the tree planter area.
Were the channel drains provided by the builder or did you but them yourself? We are wanting to go with something like that for where the pool deck meets my outdoor kitchen and the builder has round drains in the drawing, so we will be changing it. I can order the drains myself, just wondering if you found a good deal on them because Home Depot seems really high.
