Well we are almost done with our new build and after much to do with a reputable builder we still have some issues. First I will try to describe my pool:
1) Be able to turn the heater bypass to the heater when the spa turns on, I am doing that manually
2) Turn off the slide to the waterfall to take advantage of the VSF pump and run at a lower speed when not used, manually set.
3) Also When using the spillway I would like to activate my skimmer which is set to the pool bottom drain and is also manually set right now.
There are a lot of other things that need to be done like hooking up my Waterfall LED transformer to the easytouch system and so on. I have been reading around this site and there is a great body of knowledge so I thought I would post to get involved!
Any insight would be helpful...
Regards,
Brian
- Odd shaped 20K gallon pool with 12" raised spa
- Grotto waterfall with a slide
- In floor cleaning with auto deck chlorine
- UV Sanitizer
- 2 3hp VSF pumps, 1 for water feature, 1 for pool
- Pop-up splashdown in Spa
- ETI 400K Heater, Cartridge Filter, with a Cyclone after the pump
- Globright lights in waterfall and on baja step, plus led lights in pool and spa
- Easytouch8 controls with wifi interface.
- 2hp air pump for the spa jets
Regards,
Brian
