Hi! We are so new to IG pools, so I am very grateful to have discovered this forum. I am usually long winded so I’ll do my best... I’m lying... this will be long!
Our home is on a man made lake with an HOA in south Texas. We are limited to pool location and size due to setbacks, easement, building codes, etc.. I have met with several builders and have a design that gives us what we want and maximizes space. I have attached a picture of what we like.
The pool measures approximately 22x12 of swim space with a 7x7 spillover spa. Pool depth ranges from 3-5.5 ft. We included long bench seating on one side to be able to look out at the view. We have a covered concrete slab patio that we plan to have overlaid with decking to match whatever decking we opt for around the pool.
Before we select our builder, any input on the following?
Pool finish - most seem to do quartzscape although one does a pebble finish from a concrete company in Arizona or New Mexico, I can’t recall. What to watch for or be weary of...
Pool decking and coping - I get mixed answers... some swear by concrete with spray deck, while another pushes travertine, and then another only does pavers. I’m concerned about not raising my patio too high with whatever I top it with so it doesn’t get too close to the door threshold. I’m also concerned about durability and maintenance as well as safety for whatever we select. Money is an object as well so I don’t want to go crazy on the decking if it’s something I can upgrade later. Any ideas about stamped concrete with a spray deck/acrylic overlay? If we do concrete decking, is concrete coping an okay choice as well?
Pool equipment - everyone here uses Pentair. I want the Intellicenter. I’m torn between basic chlorine and the SWG. Convince me which one is truly lowest/easiest maintenance and cost! I also really think I want a chiller for the pool. It is usually so hot here and I am worried the pool will become a bathtub in the summer since it’s not that big.
Any other features or thoughts to consider??? Hoping to make the final decision over the next week.
Thank you all in advance.
