Here is hoping they can get the liner locked in. Have them put liner lock on it to make sure it stays in. They should have it on the truck. It looks kind of like white "rope" only it is rubber.
Kim
I'm sure we can get it clean. You guys are a great community!Like @Newdude said we can fix that right up!
LOL, I did practically nothing to clear it up. Just ran the filter and threw in the robot a couple of times. But yes, I probably would have been more concerned it if were summer time.Now that you know what to do, follow the rules if it ever happens again
The pressure never really went up. It reads virtually zero on low and just right at 4 PSI on med-low. Does it matter what rpm I use as my clean base-line?ewwwwwwwwwwwwwww that needed to be done!!! So how high was you pressure on the filter gauge?
Good job taking care of your pool!
No, but more rpms will be more psi. It may be easier to tell the 25% difference at 22psi than it is at 4 psi depending on the guage. Get a clean baseline at high speed also.Does it matter what rpm I use as my clean base-line?
