Yup and it worked out great with it raining on and off the past week of the gunite being put in placeLots of work done! SWEET!
Kim![]()
Should be soon. After that they have to install the deck then install the pebble sheen.Started??? It looks like it is almost done! NICE!! When do you think they will do the grout?
Kim![]()
I am going to ask about this but I am not sure.What is the pvc coming out of the spa coping?
Are you doing any sort of fountain/water-feature, that's typically what that plumbing would be for.I am going to ask about this but I am not sure.
Yes we are having the water scupper (water fall)Are you doing any sort of fountain/water-feature, that's typically what that plumbing would be for.
No just water from the pool and scupperI see the water feature on the wall, but I'm still not sure on the spa coping. A scupper there would seem a bit odd since it could only go into the spa. Are you having any sort of deck jets that will spray water from the spa coping into the pool?
Ok I figured it out what it was per the company... in their words... “Those pipes will be cut flush with the coping and a fitting will be installed that controls the air mixture to the spa jets.”No just water from the pool and scupper
Looks great!!!Deck concrete is poured. I am also going to be getting a deck anti slip coating and to have all the concrete match the same color.
