I just upgraded from a 10-year-old Aqualink RS to the new RS8 version (rev. T) and added iAqualink along with my existing hard-wired One-Touch panel and SpaLink controller. I have separate spa and pool systems (a pump and heater for each) and they connect only by a diverter valve that sends some pool water to the spa for a spillover when selected.
Everything is wired as it was on the old Aqualink RS board, but something is amiss with the heater controls. Even when the spa pump is on, if I'm not in Spa Mode I can't turn on the spa heater like I could before; the interface shows the spa heater as on but not as "heating" (like it would if the pump were off). If I select Spa Mode and turn on the spa heater, it starts up but the pool heater also starts up, and if I then try to turn off the pool heater, it doesn't respond to the command (presumably because I'm in Spa Mode). If I am not in Spa Mode and I turn on the pool heater (with the pool pump running), the pool heater starts up as expected.
Also (and maybe related), the iAqualink app and web interface as well as the One-Touch panel now display only either the spa temp or the pool temp but not both when both pumps are running. They show the spa temp if in Spa Mode and the pool temp otherwise.
It seems like maybe the Aqualink board doesn't understand that I have dual systems rather than a combo system, but all the jumpers are the same as they were on the old board.
Any answers or suggestions would be much appreciated!
