New to pools and I had mine completed last October and this is the first "season" we will be swimming regularly... After making 3 trips to the local leslies and reviewing each print out which was always counteracting the previous one and spending $$$ to get it "in check" per there advice it was enough for me to fig this out my self. so here I am... the first issue I had was a somewhat teal color to the pool. It has been 6 or so months so I cleaned all the filters (4) which were nasty and proceeded to get some advice from the pool store. My printout showed high TA (200)and high PHO (500) FC (4ppm) PH 8+ and salt at 3.4 I did there recommended doses and had another printout.. TA down .2ppm PHO no change and FC 0. PH 8+and salt down to 2.7??? third trip I after more chemicals added to increase my CYA, bag of salt now more muriatic acid and PH reducer the pho dropping to 300 and to 6.8 and FC not changing I had enough.... I thing half of it was their calculation of my pool size. I just recalculated it and they had me at 11,300 gallons where my calculation shows 17,400. They also told me to add three bags of shock which has done nothing... My SWG during this process of three weeks when from 3.4 to 4.0 with no signs of FC increasing I used test strips but I just bought a Taylor K2006 and will be doing my own upkeep from now on. I believe I am on the right track with the calculator and process to stabilize everything learned here so far but I do have a question regarding stains. It appears on the sides of the pool area a almost light grey streaks and one spot on the floor about 12" diameter. I am not sure what this is or how to rid of it. I treated the pool with metal free, vitamin C seems to make it disappear but the metal free didn't quit get ride of it.... Should I start with SLAM method? advice good or bad...
-Mike
-Mike
