Pics do not do it justice! Try to get your hand on a sample and take it out in the :sun: now that is some BLING!
Kim
Kim
It's a beautiful design! A thought on the decking situation: I'm thinking about dirt/grass getting in the pool via feet. Maybe a stone/paver path to the pool from your existing concrete? That way it's temporary/movable, but you save your sanity a bit. (I think of how dirty kid pools get when they're plopped in the grass!)
I think it's a great idea to wait to make a final decision on the decking. I had dirt around my pool the first season. I too have grass b/c I wanted a more natural look w grass. I've had it 3 seasons and I love it. It's super cheap compared to pavers or even concrete and you can easily remove it to add concrete or pavers in the future. Grass by the stairs would get pulverized if you have more than a couple of people using the pool so I did pavers on the stairs end. If you do it, lay sod though (not seed).
Good picks there!
Make sure to ask for the waterline tile to be brought a little early so you can pick through the boxes. There might be some that are extra pretty that you will want put on the eye fall places. Where the eye falls as you walk out to the pool. Then there will be some that are plain ugly so you will want to hide those LOL
BOOOOOOOOO on having to move the lineAt least you found out BEFORE they started digging!!!
we had one build where it was found during the dig............ewwww to the max!
Kim![]()
Fantastic job!! I’m doing the same in Houston with grass between large concrete slabs.
What kind if grass did you use??
I’m wondering the same from that post! What kind of grass are you thinking to use? I was thinking to replant the yard with Bermuda since I currently have St. Augustine which I do not like the texture of.
This is the best photo I have at the moment. I am installing large slabs with grass between each of them and between them and the pool. I’m considering Momo Grass. But I’m not really sure that it’s the correct application for Momo. Bermuda may be a solution, but I’m concerned about the radiant heat (I live in Houston) coming off those slabs - it may retard the Bermuda. Thoughts?
Let some of the MUD begin!!!
Time line=longer than you want and will never seem to end! Don't go banking on any kind of time line. Just as for what step is next.
Do you have any idea how many builds your PB has right now? That will impact your time line as much as anything due to subs backing up.
Kim![]()
