CJadamec
Best to run the pump during the daytime hours when the air is warmest. Evening and nighttime running of the pump will cool your pool down.
It ends up being a personal choice really.
I'll tell you my method, other members choose differently. I have 3 kids + their friends that swim in my pool and kids do things that kids do. Like track dirt, grass, odd stuffed animals (toys) and swim for hours without getting out. We have a no-P policy for the pool but you never know. I dose my chlorine bleach through a Stenner pump in the evening around 9pm. This is almost always after the last swim for the day and will be when the pool will be it's dirtiest. This allows the FC to work it's magic overnight without any loss to the sun. I use a solar cover overnight. This really helps keep the heat in at night.
My electric rates don't change based on time of day. I know I don't need to, but I typically run my pump on low speed 24/7 regardless. It makes my wife happy to know that the filter is cleaning all the time. For the extra $10 a month, it's worth it to her. I’ve never done any testing to see if the pump off overnight helps retain heat better.
What is the name brand of steps and where did you you get them? I like that they are not solid white like every other set I've seen
i thought on the low setting I would let my pump run all the time too, so do you need or use a timer? Don't you think running pump that long will really reduce your pumps life?
It's all coming together!!
He loves them so long as you do not use them ON him or because of him. You know if he upsets your daughter! LOL
Well done sir! That is a lot of work and it looks like you did it right!
So here comes my "Kim/girl" question......digging bar? You had a machine to dig the holes. WHY would you need/want to use the digging bar? Just let the machine do the hard work.
Kim![]()
Mr b from how did you come to the hours of running the pump? Can you run the pump in the evening with the solar cover on the pool?
