- Apr 25, 2022
- 293
- Plaster
- Hayward Aqua Rite Pro (T-15)
Cool! But where are you getting TC from?Proper Taylor’s test kit. Even had my other half confirm my color matching so it’s definitely the right numbers.
Honestly I don’t know what any of this means? I just used the Taylor test for FC. Then added the extra drops for TC. Then did the math.You test for CC in the TFP method. We don't calculate it, nor do we worry about TC. We use the FAS-DPD method to test for FC then, using that same solution you just tested, we test for CC.
Don't use the OTO method. It's only accurate up to 5 ppm FC, and TFP pools generally have a higher FC than that.
By following these instructionsCool! But where are you getting TC from?
I don’t know - it’s the Taylors one made for Leslie’sYeah, don't use the OTO block. Use an FAS-DPD kit and test your FC and CC. What Taylor kit are you using? We recommend either the TF-100 from tftestkits.net or the Taylor K-2006C Test Kits Compared.
What’s an OTO block/testYeah, don't use the OTO block, the color comparator block. Use an FAS-DPD kit and test your FC and CC. What Taylor kit are you using? We recommend either the TF-100 from TF Test Kits or the Taylor K-2006C Test Kits Compared.
Ok I think I understand. I need this right? I don’t need an entire new test kit do I?Yeah, don't use the OTO block, the color comparator block. Use an FAS-DPD kit and test your FC and CC. What Taylor kit are you using? We recommend either the TF-100 from TF Test Kits or the Taylor K-2006C Test Kits Compared.
Or this actually…Ok I think I understand. I need this right? I don’t need an entire new test kit do I?
Thank you! I get what you are saying now. I will order one. Appreciate the help. And the patienceThat kit has everything you need except for a FAS-DPD chlorine test. The color comparitor test (OTO) doesn't go up high enough for Trouble Free Pool methods, and isn't particularly accurate either. It's good for seeing IF there's chlorine in the pool, but not great for saying how much.
You should augment the kit with this: FAS/DPD Chlorine & CC's test
Edit: in reply to your last post - YES!
One more thing - but if I was using the calculation method - am I doing it correctly? Is the number I got at all accurate?Thank you! I get what you are saying now. I will order one. Appreciate the help. And the patience
