Needing advice
mknauss
23,066
Laughlin, NV
When you do the CYA test, try this next time.
Once you have your solution ready, back to the sun, etc. Fill the vial to a line, say 80, lower the vial to your waist level and glance for the dot, you see it, add solution to the 70 line, glance, see it, repeat until you no longer see it with a glance. Then use the CYA value one step above the line you read. So if you stopped at 50, use 60 ppm CYA.
The vial is in logarithmic scale. So it is not viable to interpolate between the lines. Just use the whole numbers, such as 50, 40, 30, ....
Jubenez
47
Indiana
I did that method. I think it is 70 or 80. My eyesight is not that good, I'll have my husband try but he isn't home in daylight hours.
At 70-80 would you dump or SLAM?
justinc
591
Texas
You can continue to SLAM without dumping you will just need to make your SLAM target 31ppm for your free chlorine. Harder to hold it there at a higher level
ajw22
11,851
Northern NJ
Don't agonize if it is 70 or 80. Round up the CYA test and call it 80. The test is only accurate to +/- 10 ppm anyway.
Long term you want to get your water down to CYA 30 to be more manageable. If fill water is not an issue then doing a water exchange now will lower your CYA and dump alot of the algae out. The SLAM Process should then go faster and require less chlorine.
You need to drain about 50%-60% of your water. You really don't want to drain a pool with an old liner. @mknauss can tell you how to do a water exchange.
mknauss
23,066
Laughlin, NV
Let's not talk drain yet when you added CYA recently due to it testing 0. I suspect your testing protocol for the CYA is an issue. You are staring at the dot. Don't do that. You will see it forever if you stare at it.
mknauss
23,066
Laughlin, NV
Liquid chlorine has no CYA.
So you might have had 20 ppm CYA to start. So now you have ~50. Use that for SLAM level FC. And test the CYA tomorrow using the process I described above.
Jubenez
47
Indiana
So are you thinking I'm reading the CYA test incorrectly? I performed it 2 or 3 times today (with the same sample).
Would adding hth super shock (56% calcium hypochlorite) cause any issues?
justinc
591
Texas
Stop grasping for additional things to throw in the pool and just stick with liquid chlorine. Calcium hypochlorite has no benefits over liquid chlorine and has many drawbacks. Don't add more variables to complicate your situation. Keep it simple.
Jubenez
47
Indiana
Okay you are right... it's just that I've added probably 50 gallon of chlorine to a pool that is still green. 😢 I will resist the urge!
czipper
82
Long Island, NY
You are in good hands here, these experts know what they are doing and really want to help. Take a deep breath (maybe a day off even, if it is bringing you to tears). Then take stock of your situation and everything you have learned and get back into it. If you are unsure, ask BEFORE you do.
YippeeSkippy
12,067
Evans, Georgia
I just want to clarify that you're testing your FC with how much pool water- 5cc? or 10cc?
If it is 5cc, each drop of 0871 = 1ppm
if it is 10cc, each drop of 0871 = 0.5 (which just means count all the drops then divide by 2)
Maddie :flower:
Jubenez
47
Indiana
Thank you for the reassurance. I just had high hopes for this weekend :) I'm not giving up!
Jubenez
47
Indiana
Maddie :flower:
I'm using 10 ml water and 2 level scoops of the powder. Now I understand that a drop is equal to .5 ppm but initially i had it wrong (bad advice from local pool store).
Is it okay to test at 5 ml sometimes to save on drops? Maybe not right now bit after i get everything cleared up?
Thanks!
justinc
591
Texas
You can use 5mL for a quick check and during SLAM to save on re-agents but if you need to know a more accurate level then the 10mL or 25 mL samples are better choices. I use 10ml for routine testing and 5mL for SLAMing
