I did that method. I think it is 70 or 80. My eyesight is not that good, I'll have my husband try but he isn't home in daylight hours.
At 70-80 would you dump or SLAM?
I added about 6 lb stabilizer.How much CYA powder did you add? Need to check PoolMath to see what it should have raised your CYA by.
No not really. I had it tested at Leslies then myself for comparison.So you have added 35 ppm CYA, give or take. Your first test of the CYA, when you said 0, was it cloudy?
So are you thinking I'm reading the CYA test incorrectly? I performed it 2 or 3 times today (with the same sample).Liquid chlorine has no CYA.
So you might have had 20 ppm CYA to start. So now you have ~50. Use that for SLAM level FC. And test the CYA tomorrow using the process I described above.
Stop grasping for additional things to throw in the pool and just stick with liquid chlorine. Calcium hypochlorite has no benefits over liquid chlorine and has many drawbacks. Don't add more variables to complicate your situation. Keep it simple.So are you thinking I'm reading the CYA test incorrectly? I performed it 2 or 3 times today (with the same sample).
Would adding hth super shock (56% calcium hypochlorite) cause any issues?
Okay you are right... it's just that I've added probably 50 gallon of chlorine to a pool that is still green. ? I will resist the urge!Stop grasping for additional things to throw in the pool and just stick with liquid chlorine. Calcium hypochlorite has no benefits over liquid chlorine and has many drawbacks. Don't add more variables to complicate your situation. Keep it simple.
Thank you for the reassurance. I just had high hopes for this weekendYou are in good hands here, these experts know what they are doing and really want to help. Take a deep breath (maybe a day off even, if it is bringing you to tears). Then take stock of your situation and everything you have learned and get back into it. If you are unsure, ask BEFORE you do.
I'm using 10 ml water and 2 level scoops of the powder. Now I understand that a drop is equal to .5 ppm but initially i had it wrong (bad advice from local pool store).I just want to clarify that you're testing your FC with how much pool water- 5cc? or 10cc?
If it is 5cc, each drop of 0871 = 1ppm
if it is 10cc, each drop of 0871 = 0.5 (which just means count all the drops then divide by 2)
Maddie![]()
