The pool was opened on Wednesday, but I forgot to refill it so I’m not sure what the pool company did in setting up valves (water level was far below the skimmers).
I filled it up to the proper level but the skimmers are not pulling in water, the Polaris is not working and there’s no pressure on the filter gauge.
The labels on the pipes and the valve settings were from many years ago when a competent pool guy talked me through a different problem over the phone. The written labels are correct, but I’m not totally sure the valve positions are correct. But they should be since I took photos of them!
Anyhow the photos below match my historical photos but nothing is happening. The motor is hot and the water in the filter basket above the motor is warm.
This is a shot of whole set up. Polaris motor (hidden under pipes), valves to solar heater, filter and main pump.
