I need some help with what settings I should leave my valves on. We bought the house recently and the previous owners had nothing labeled. Our pool is 18,000 gallons, salt water fiberglass pool.
I tried to hook up the suction vacuum today and was not sure what RPM to set my variable speed pump at (I choose 2600 RPM) is that good? It did work for a bit then the hose disconnected off of the hole in the skimmer (it is the only place in the pool to put the hose for the vacuum).
Also, I am not sure how to turn off the main drain? I attached a picture so you could see/hopefully help me out as to what I should set these valves at for 1) basic running and 2) vacuuming/cleaning. I would like to leave the vacuum in the pool and set the pump to clean it for 3 hours during the night/early AM.
Any suggestions/help is appreciated. Thanks in advance!
