I am using a Taylor 2006c kit.
I tested the incoming water at 250ppm
Pool water before replaced was at 650ppm
Here is what I’m doing.
Since its the summer heat and I’m trying to fix the pool guys idiocy by allowing my CYA to climb to 180, I’m replacing the water but filling it at the same time.
I’m pumping out from the deep end on the step and filling in on the shallow end.
So far my CYA went do to 100, but my hardness has stayed at 600ppm. I’m really lost because the incoming water is 250 the pool should have gone down to 400 or less at this point.
Any help would be appreciated.
