- May 3, 2014
- 62,922
- Fiberglass
- Pentair Intellichlor IC-40
Believe what you will -- CYA does not stick to or degrade plaster.
Thank you so much for all your help and advices!Believe what you will -- CYA does not stick to or degrade plaster.
The article & study done by Pulsar was interesting. My main concern is that they did not isolate pH, alkalinity and calcium hardness to determine what individual affect each of those have on plaster etching regardless of CYA levels. Also, they used carbonate alkalinity measurements at fairly high levels which implies that actual TA levels are even higher which are significantly above the recommended ranges for any pool. The study was done 15 years ago and I could not find any follow up so IMHO, they really did not make any conclusive findings regarding CYA effects on plaster.
I think @duraleigh & @mknauss have it right.
