I guess you are about complete by now but why are you brushing? Brushing is a VERY good part of your normal maintenance but don't do it because of this exchange.
It often does but you cannot take that to the bank. My suggestion would be to leave it at 85 and test it a couple of times this winter to judge the trend. Absolutely no more tabs or you will be right back where you started.Do you think the CYA will go down over the winter month if I have the pool tech not use anymore tablets in the chlorine dispenser?
I would like to have seen it lower as well but I don't think I would set up the rig again unless it is super easy to drain another 30%. If it was my pool, I would leave CYA alone and monitor it. Are you going to close (cover) the pool?
Go to the bottom of the page and click on classic web version of PoolMath. Enter your pool gallons at the top, then enter in the far left "Now" column that you have 4ppm of FC, then in the next column where it says "Target" enter 6....or however much you want. Go all the way to the bottom of the page and tell it you want to follow "Troublefreepool.com", "bleach" and "plaster" for those options. You'll see to the right off the FC area how much to add.
Play around with it. It is a GREAT help to pool owners. Get the App version for your phone, if you desire.
It looks like 45 ounces of 6% will take you up to 6ppm from 4ppm.
Maddie
My recommendation is that do all tests daily for several days if you are new at doing this. It will give you some consistency and confidence. Then you most likely can test FC and pH daily, TA and CH every 5-7 days and CYA as needed. When i started I tested CYA more frequently but once you get it stable then every couple of months should be fine since you now have switched to liquid chlorine. For example, prior to TS Beta coming into Houston area, I tested my CYA, drained 6 inches from the pool and let the 2 1/2 days of rain fill it back up (and more -its at very top of my weir flap in skimmer). I then tested CYA again. My CYA dropped 10 points. If you ever use pucks again (like if you go out of town for several days) then best to test your CYA before and after.Another question....
If I decided to keep on just adding liquid chlorine into the pool and not use any tablets, do I need to do a test for everything else, too, everytime I check for FC level?
What was the powder shock? If Cal Hypo, it added calcium. If Dichlor, it added CYA.
Yes, I really like where my Calcium was at. Will that amount raise calcium hardness up a lot? Is that easier to reduced if high?That is Cal Hypo. Adds chlorine and Calcium. According to your Poolmath logs, you do not need more Calcium, either.
That one dose will not raise it much --- check out Effects of Adding Chemicals in your Poolmath app. But continuous usage will raise calcium significantly. Use Liquid Chlorine.Yes, I really like where my Calcium was at. Will that amount raise calcium hardness up a lot? Is that easier to reduced if high?
I've ran across a couple of articles regarding CYA on plaster. Have you seen this one?CYA does not stick to plaster. It is in the water. It will only go up if you add more.
I recommend you sever the services of that individual.8
Ok I will use liquid chlorine.That one dose will not raise it much --- check out Effects of Adding Chemicals in your Poolmath app. But continuous usage will raise calcium significantly. Use Liquid Chlorine.
