I want to make sure i have everything right as i refill DE to restart pool. The pipes are not labelled and i just wanted to get an idea if i have it right before restarting the pool
I am not sure of all the equipment. It has a booster pump from old.owner but we use a dolphin. There are about 4 jets in the pool i believe. It has a waterfall, spa, blower. I have attached pics of the set up and i can take more if needed
I have not used it in 3 seasons and when we did, i had a pool guys that showed us only how to cut on the different functions. The bags are around spots that had minor leaks and he put them around it, he said i will need a plumber for that. It is a polaris control panel with a salt system
I will post panel pics once i get home. I just want to understand which of the valves is for the drain, skimmers, spa so i have a better understanding of how to run my system
