Need help picking a Slide
How old are your kids or grandkids or this for big kids?
The first slide is a faster slide and you launch further. The second is bigger and I think funnier but not as fast. And it costs more too. Regardless you need a water connection for either otherwise they aren't great. Hopefully you have one nearby or are building new and knew about the water feed
You can dig up a return and T into it. You can run a flex line from pool return to slide. You can run a water line from the yard like a hose bib. Depends how your pool area is laid out
My goal is to run a Y diverter and then put a automated valve so when no one is using the slide I just have it set to off. Im planning on having it set as a feature on my easytouch
Reactions: MyAZPool
