I’m new to this site but anytime I google about anything, this is where I end up! I’ve decided to stop looking elsewhere for advice. The pool store has helped very little and we’ve been in several times for testing & purchasing pricey products. My head is spinning with the amount of information received. I had no idea how complicated pool operation could be!
For background, we own a smaller above ground 8k gallon saltwater pool. I’m new to dealing with all of this as my husband typically takes care of the testing & maintenance. We’ve had no issues since we had the pool installed 2 yrs ago. However, we opened to a green pool this year & were baffled as to how to proceed. We couldn’t get anyone to come out as they have all been too busy! For a month, we have added & tried almost everything. Metal out turned the water from green to aqua, algaecide, chlorine shock, bleach, clarifier, flocculant, Muriatic acid.. along with constant scrubbing, vacuuming & testing water. None of this has cleared our cloudy pool & have seesawed back and forth with balancing.
When we got our levels to a good balance, we hooked up the SWG, per advice received. The water has cleared somewhat but still extremely cloudy. I was just able to somewhat see the bottom yesterday. We have never entered the pool due to safety concerns. I can now see that the bottom of pool is mostly white. I don’t recall that it was like this prior to closing. We have been adding straight 8% bleach according to pool calculations each night for several nights with pump running 24/7. I tested water today with strips as well as Hydrotools test kit and the current readings are:
Ph 7.7 (Will add MA to reduce & hopefully bring TA down too)
TA 150
CC 0 (Despite adding bleach)
TH 300
CYA 10
I am about to purchase additional Chlorine to to begin a Slam process as I read in a previous post. The calculator suggests 42oz of 10% bleach to be added. What are your suggestions for what I should do prior to this. Should I disconnect the SWG? Add MA to reduce PH? Purchase & add Stablizer tablets to increase CYA? Purchase & add DE for sand filter (has never been done)?
As I said, I’m totally new to this & not sure if I’ve been clear or using correct terms! I’m just looking for any suggestions on here so we can begin using our pool in this 90 degree heat! I have my sons pool party scheduled for next Saturday too
& can’t let kids in a cloudy or unsafe pool!
Thank you in advance!
TA 150
TH 300
CYA 10
