Hi All,
This is my first full year of running the pool myself and I have a few questions based on the following numbers:
FC. 6
TC. 0.5
TC. 5.5
CH. 500 ( very hard water here in San Antonio, Texas )
TA. 70
pH. 7.5
CYA ( I know I may need to add something here, but not sure what to get. Chlorine seems to be going away quickly and it’s not even June! I’m adding about a gallon a day of 6% bleach.)
I am only using chlorine bleach 6%, or 8.25%, when I can find it; muriatic acid, and baking soda.
Secondly,
I also have an Intex portable, inflatable hot tub set up under a canopy with the following numbers:
The temperature is set at 96°F and holds 210 gallons
BR. 5-10
CH. 150 ( it has a calcium remover in the filter which explains for the lower amount of calcium in this water versus my pool water. Wish I could hook this filter up to the big pool! )
TA. 180
pH. 8.2 plus
CYA. 0
You guys helped me get rid of the pool guy last year and I sailed through the winter, but now I need a little assistance in selecting stabilizer, if I need it, and tweaking these numbers somewhat to make it chlorine efficient for the summer.
Thanks for the help.
Sherrie
FC. 6
TC. 0.5
TC. 5.5
TA. 70
pH. 7.5
Secondly,
BR. 5-10
TA. 180
pH. 8.2 plus
CYA. 0
Sherrie
