I have a Jandy DEV 60 filter. About a month ago I noticed water on my concrete pad around the filter, but couldn't find any moving down the body. Had local pool guy out, he performed a deep clean of the filter (it was time anyway). Once back up to pressure the leak started again.
His theory is there is a small crack at the bottom part of the filter that only leaks when under pressure. Makes sense to me.
So now I have a couple of decisions to make:
1) replace bottom half of the current setup. Quote is about $1100.
2) replace entire filter with the same model. Quote is about $1850
3) replace entire filter with a different type of filter (this is where you guys come in!!!)
What would you do? Would you stick with DE? Is there a better option? If sticking with DE, would you do partial or full replacement?
Also -- I'm open to seeing if my guy can just do the install and I get the equipment myself if that's an option. I'm thinking about Margaret at Marina with the robot....I learned about her here, and saved a bunch of money....I've sent several people her way as well. If there a place to get filters that would save substantial money?
Thanks in advance....this community is awesome so of course this is the first place I came.
Cody
Cody
