I'm tired of my Jandy LED lights going bad.... I need another CPHVRGBWS100 (Jandy WaterColor LED RGBW Pool Light - 120v, 100'-CPHVRGBWS1) and I'm getting tired of replacing these every few years at $980 each.
I have 5 pool lights:
My requirements:
Any thoughts? Comments? Recommendations? Remember these are 120V lights, not 12V lights.
- 2 of which I've already replaced with LED strip lights (for the upper spa and disappearing edge basin, LED strips are mounted under the patio coping pavers)
- 1 of which will -never- work again because the wiring cannot be pulled through anymore (unless I tear up 50' of patio and yard to determine where the blockage/kink is)
- 2 of which still use the CPHVRGBWS100 Jandy lights (need 100' cords)
My requirements:
- Light must power on automatically when the relay comes on (via scheduled Aux in my iAquaLink) and deliver 120V to the light
- Light must also remain set to the last selected color, meaning if I set the RGB as Blue, when the relay is turned on automatically by schedule the following night, the RGB should be Blue again (without having the manually change the color every night).
