Hi Folks, I'm hoping someone can point me in the right direction here.
I have a relatively new Pentair MasterTemp 400 Natural Gas Heater. The heater works well when running but I'm having a delayed ignition issue where ,sometimes, when it clicks to turn on it will delay and then start about 30 seconds later. When it does this I'm guessing the combustion chamber is filling up with gas and then igniting which creates a big boom. Sometimes flames shoot out the vent and sometimes it does not.
While it still works great, I hate having something that is new do this.
I've had the company out that did the installation and he seems to think it is low gas pressure. However, unless the specs on the MasterTemp are incorrect then it shouldn't be causing an issue.
I've tried a lot of difference scenarios to see if perhaps something was going on that might be dropping the pressure. The Pentair manual says that the minimum is 4in W.C. and Maximum is 14in W.C.
With the manometer hooked up to the inlet port:
Thanks for the help
- Everything off at the house that uses gas:
- Before ignition I'm right about 7in WC. Which is right where it is set from the gas company.
- Turned on and heating - 4.62in WC
- Running the Tankless + the Pool Heater - 4.58in WC
- Tankless + HVAC Heater1 + Pool Heater - 4.46in WC
- Tankless + HVAC Heater 1 + HVAC Heater 2 + Pool Heater - 4.33in WC
- Tankless + HVAC Heater 1 + HVAC Heater 2 + All 5 burners on my stove top + Pool Heater - 4.32in WC
Thanks for the help
