Hi All, I have not posted in a while. I have a problem and was hoping you can provide some guidance. I have a 13-year-old pool that has had solar on it since day one. I just noticed that the option for Solar is gone from the Jandy One Touch. I have an RS8 controller.
I did not touch anything other than to turn the power off to the pool to open the heater and blow out the dirt that was in there.
When I look at diagnostics, it says the solar is Open. The valve is closed though. The pool equipment shows the orange light near the solar indicator, but again, it is not on nor is there an option to turn it on or off. Every other setting is still in the controller still shows the different speeds we set for the variable speed pumps so it does not seem like it reset to defaults. When I goto system setup, assign JVA's there is nothing listed for solar. The top two options show "used" though and when I click on solar, it gives me options for Aux 1, 2, 4, 5, 6 7.
Any ideas or should I call the pool person?
