Well we got about 6.5" inches of rain here, not as bad as many people but still enough to make the pool overflow. I ran the SWG for extra time before the storm to pre-emptively raise the FC level and that seems to have worked. Now all of my numbers make sense... except the salt level. My CYA and borate levels are exactly the same as the previous test about 2 weeks ago but somehow I seem to have lost a LOT of salt. Here are today's readings:
FC 11
pH 8
TA 60
CYA 70
Salt 2200
Bor 48
The salt level was 3200 when I last tested it. I did the drop test twice to be sure and it took 11 drops each time to get to brick red. Then I took another sample from a different part of the pool and it took 12. If there was enough water replacement to drop the salt by 800-1000ppm, shouldn't I have lost a lot of CYA and/or borates as well?
The other weird thing is that my SWG is still happily generating. It hasn't given me a low-salt message. I would have expected an error under 2500, but I've heard that might not be totally reliable.
I can add some salt but before I do that, I'm looking for a sanity check. Is it possible that I lost salt and nothing else? Or could something be causing an incorrect reading?
FC 11
pH 8
TA 60
CYA 70
Salt 2200
Bor 48
