- Oct 11, 2021
- 10
- Plaster
- Pentair Intellichlor IC-40
Hi All,
I had a pool installed (construction began Labor Day weekend) and it was just filled ~2 weeks ago. Plaster crew applied Wet Edge Signature matrix plaster on a Thursday, did the acid was Friday, and put the hose in when leaving so the pool would fill. Well, the plaster crew forgot to plug the drain holes so from Friday-Sunday AM the hose was running but water level not increasing. I finally was able to get the pool company out Sunday morning and they plugged the drain hole, pool filled fine.
Because the water level was not increasing, there is a "ring" or water line on my pool where the water level had remained stagnant. What can be done for this, if anything?
