It’s mostly cosmetic.
Also, people’s hair can turn green from copper, especially blonde hair.
The main chemicals for removing metal stains are ascorbic acid, citric acid, oxalic acid and sulfamic acid.
Jack’s #2 is sulfamic acid, which is the most effective on copper.
You can also drain and acid wash or drain and use a diamond grit power sander on the plaster to remove stains.
Power sanding also smoothes the surface.
Acid washing makes the surface very rough.
In the earlier pictures, they chose to acid wash and it came out pretty nice, but the surface was very rough.
You can also try a “No-Drain” acid wash, which is where you lower the TA to zero for a while to see if the stains will lift.
Zero TA can damage metals like copper in the heater, handrails and lights, so it is not a good choice if you have metals that can be damaged.
