- Dec 11, 2016
- 64
- Jandy Aquapure 1400
Greetings.
I have searched but cannot find an answer on this. I am running down a vacuum leak in the plumbing (I have read all the threads) but I cannot determine if the pool motor shaft seal is on the pressure side or the vacuum side. Said another way, could the motor shaft seal be the source of bubbles in the pool return? To me it seems like it would be on the pressure side, but something is nagging at me telling me that it could be vacuum as well be cause it is on the exact opposite side of the impeller as the inlet. The impeller seems to create pressure tangentially and not longitudinally like a boat motor.. Just thinking out loud here.
15k in-ground cement pool, Intelliflo VSP, Sand Filter, etc.....
Thanks in advance.
Thanks in advance.
