I'm in the process of replacing my years old pump & sand filter. Presently, my pool is plumbed with 1.5" PVC. The run is fairly long (estimate 30+ feet to the pump & then more on the return). I ordered a 2HP variable speed pump which comes with both 1.5" & 2" adapters. The filter will be replaced later with a cartridge filter which has 2" in/return fittings. Plus I'm going to install a salt system (next season?) which also uses 2" fittings.
My plan is to plumb the pump for 1.5" entry, then 2" exit to 2" filter in to 2" to 1.5" adapter return. Eventually the 2" salt system will be installed between the pump exit & filter in. I figure this method uses the least amount of adapters since my pump/filter shed is kind of a tight space to work in.
Any problems with this tentative plan? Suggestions? Thanks!
Kevin T
Kevin T
